opening a new front panel
Then you need to use asynchronous call. Check the help for that.
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 14
(825 Views)
Dear
Please Find the attachment bellow.
Message 12 of 14
(821 Views)
Dear
Please Find the attachment below:
Message 13 of 14
(821 Views)
It is not considered polite to post VIs with infinite loops without warning that the vi will not stop on its own. "The use of the Abort button to stop a VI is like using a tree to stop a car. It works but there may be undesired consequences."
To elaborate on the suggestion by
To fix this you can use asynchronous calls as Yamaeda mentioned or the subvi could be called in the consumer loop of a Producer/Consumer architecture.
This program can be done without local variables, without global variables, and without sequence structures.  All of those are rarely needed in well-written LabVIEW code and are not appropriate here.
Lynn
Message 14 of 14
(806 Views)
