open file gxml in excel
How do I open an XML file iIceated in LabVIEW with the GXML VIs?
Scientia est potentia!
(3,776 Views)
You should check out the examples for an intro into using the XML functions. From LabVIEW select help >> Find Examples, then click through Fundamentals >> File Input and Output, and look at the Read Data from XML File.vi and Write Data to XML FIle.vi examples. Those will get you started.
--Ryan S.
(3,747 Views)
I'd like a look in EXCEL like the attached clip.
(3,733 Views)
If you're wanting to work with an xcel doc then you probably want to use the regular text functions or the Write to Spreadsheet.vi and Read from Spreadsheet.vi functions, not XML functions.
--Ryan S.
(3,705 Views)
Unfortunately, I can not change the format of my data collection.
Someone else will look at the XML data by opening it in EXCEL.
(3,689 Views)
Could you open the XML file in LabVIEW and convert it into a spreadsheet text format, and then open it in excel?
(3,662 Views)
I decided to avoid GXML as much as possible.
(3,597 Views)
