open file as it arrive
Hi all,
I want to implement a functionality - which in a shortcut - will open file as it arrive. I get an image file from a source, this files are simple, small bitmaps named with date and time. I need to open this files as soon as they arrive, one after one. I know how frequently this file appears, but I have no idea how to
I would be very grateful for help with this issue.
regards,
Marcin
Message 1 of 10
(3,493 Views)
How are you monitoring to know when it arrives?  That is the first problem you need to solve.  The only method I know of is to consistently poll the directory and looking at the list of files and comparing them to the previous list.
The second thing is to use the new file to open it.  There are lots of examples for handling files and the graphics and sound palette has VI's for opening and reading bitmap files.
Message 2 of 10
(3,486 Views)
As a possible alternative to polling, check out this nifty example that uses .NET calls to trigger an event when a directory is changed (files added, deleted, modified or renamed).
Message 3 of 10
(3,475 Views)
Czesc Marcin :),
how do you actually send/recieve the file - e.g. what's the source of the picture?
Jano
Message 4 of 10
(3,435 Views)
Image are sent over ethernet, but it is not a typical TCP/IP. I use a special application for reading images and saving to disk, to a specified folder. data and a time of image acquisition is a image filename.
regards,
Marcin Kowalski
Message 5 of 10
(3,430 Views)
I was just asking to see, if we could get some sort of trigger signal together with the incoming images.
Since this is in software, I'd try either of the methods mentioned by Ravens Fan and nathand- the .NET solution sounds like an elegant solution.
As far as the bitmap part is concerned, you can use functions like Read BMP File VI and Draw Flattened Pixmap VI .
Please ask further question if something is not clear.
Jano
Message 6 of 10
(3,417 Views)
I have used the polling method in the past. The thing to be aware of is that you might detect and try to read the file before it has been completely written. The way I got around that was to first create file.bmp.lock, write file.bmp, then delete file.bmp.lock. My polling will see that file.bmp exists then check if file.bmp.lock exists. If so it ignores file.bmp. There are probably file properties you could read to see if something else has it open.
If using Windows the .NET file watcher works very well although I am unsure if you will have the same problem of trying to read a file that has not been completely written. I am guessing (hoping) that the trigger occurs after the file has been completely written.
LabVIEW 2012
Message 7 of 10
(3,408 Views)
It looks I understand how this works and hopefully I will cope with this task. Unfortunately I won't check that before the weekend. Thanks for all replies.
regards,
Marcin
Message 8 of 10
(3,396 Views)
Finally I tried The directory watcher. It looks good, but I don't know how to use this files to trigger open image (bmp open) function. Any ideas?
regards,
Marcin
Message 9 of 10
(3,354 Views)
I would do it similar to this one:
https://decibel.ni.com/content/docs/DOC-8962
When you receive an image, add to the queue. So basically you will have two while loops as in the link above, the top while loop (producer loop) will be the directory monitoring loop and the bottom one (consumer loop) will be your bmp file functions (for example http://zone.ni.com/reference/en-XX/help/371361H-01/lvpict/read_bmp_file/ as mentioned above)
Hope this helps.
regards,
aCe
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 10 of 10
(3,347 Views)
