open/create/replace file.vi for Excel
I have a macro enabled Excel file (.xlsm) that I would like to pr0grammaticaly open and then run the macro.  Shouldn't I be able to use the "open/create/replace file.vi" to open the file?
(3,211 Views)
(3,206 Views)
Thank you for answering the question.
Do you have a possible suggestion as to how I could accomplish the task I described?
(3,195 Views)
ActiveX
(3,192 Views)
I believe the Report Generation Toolkit has a subpalette for Macros but I don't know what you can do with it.  The Report Generation toolkit comes with some versions of LabVIEW 2014, I think Full and Professional, but was separate before that.  At the end of the day ActiveX will need to be used somehow.
(3,183 Views)
