open and write to multiple files in labview 6i
I want to open multiple files in a single application in labview and write the data I retrive via gpib in the files
(3,274 Views)
No problem. Go ahead.
(3,274 Views)
Thank-you for the quick response. I should have been more specific. I am trying to create multiple files in a single application, using the same path but different file name. The first file is being created but the subsequent files are not.
(3,274 Views)
Can you post your file creation code? It may be a slight oversight.
(3,274 Views)
It was, Thank-you.
(3,274 Views)
To create multiple files in a directory you can use the attached example.
guindon_jp@hotmail.com
(3,274 Views)
