open a graph in a new page by clicking on it
But I was faced with another problem. I could not apply graph palette (for eample, I could not zoom my graph),
Because my VI is within a loop and alternatively run.
There are two options here.  Turn off the autoscaling of the x and y axes (new data won't reset the axis range) or use a button and case structure to only read in new data when the button is pressed.  Since the graph won't be updating constantly, you can zoom all you want.
Message 11 of 13
(704 Views)
Hi
Thank you all,
I added an other event structure within while loop in Acquire Data.vi.
I chose "Palette:Active tool" ( a property from my graph) as an event
and my problem was resolevd. I could apply zoom tool in my graph.
My new VI is attached as a picture.
thanks
yasamin
Message 12 of 13
(687 Views)
Accepted by topic author yasmain62
Hi
Thank you all.
I applied message 4 ( from GerdW) in my VI.
"use an event structure to detect mosueclicks on your small graph. In case of mouseclick open a subVI with a bigger graph..."
Then I added an other event structure within while loop in Acquire Data.vi.
thanks
Message 13 of 13
(648 Views)
