open Vi object reference waveform chart
Hi, I'd like change a property of an indicator in a VI from another VI (In particular i want to clear a Waveform Chart) I used Open VI Object Reference but i am not able to access to History Data. How can I do?
(4,276 Views)
The reason you have no History Data available is that this property requires a strict reference.
Sadly afaik there is only a workaround to get a reference constant to be strict:
1. Change your "Waveform Chart" reference constant to a control
2. Right click the new reference control "Waveform Chart" and select "Include Data Type"
3. Right click the reference control and select "Change to Constant"
Norbert
Norbert
Expert: Geometry
(4,266 Views)
Ok, Thanks!
But now I have this Error:
What do I Have  to do?
(4,258 Views)
The problem in your code is that the Waveform Chart (strict) reference is a reference to a chart with a 1D double array as value.
The actual chart you have on the VI is a 2D double array. Therefore, you get a data type mismatch.
Solving it requires another workaround:
1. Create a waveform chart in the ClearChart.vi.
2. Wire a 2D double array constant to its terminal (this will change its type!)
3. Create a reference to that chart
4. Wire that reference as "VI Object Class" to the Open Reference function
5. Adopt your history constant to be 2D as well
Please note that the workaround only works as long as the chart has a 2D double array as data type. If you want a generic solution, you would have to try-and-catch the type cast until no error occurs. This also affects the History Data property node as well of course....
Norbert
Norbert
Expert: Geometry
(4,252 Views)
Sorry, I made what you have told me:
now i have this error:
 why? If you have implemented a correct Vi can you give me it please?
Thanks!
(4,247 Views)
Accepted by topic author smilegv
Ok, sorry for confusing you. I haven't checked the strict waveform reference with the Open Reference function.
Using the "good old way" works:
Norbert
Norbert
Expert: Geometry
(4,238 Views)
Ok, Thanks a lot!
(4,233 Views)
