opcode writing in VME TDC question
          I'm new to this OPcodes and wonders if there are experts out there.
I'm using VME 1290N.
I would like to change it to trigger mode using and writing register 102E
the OPCODE setup words have the following format
                15 14 13 12 11 10 9 8|7 6 5 4 3 2 1 0
                 8 to 15 is for command and 7 to 0 is for object
on the table in the dataset it list the following info
 COM OBJ CODE   SYMBOLIC
 00       -        00xx      trigger_match
 10       -        10xx      set window witdth
it says that for set-window width, it ranges from 1 to 4095 (hex FFF) with clock period at 25ns
Default setting :0x14 --> 500ns
question, how does one write to the register to change to trigger mode and width to 1000ns ?
thanks
(2,719 Views)
I cannot find any documentation on this device. I know it is made by Caen, but I didn't find a manual. Do you have the manual? If so, can you send me a link to it? Also, writing to registers is fairly easy with NI VXI and VISA. You can find examples on how to write to registers in LabVIEW. Go to LabVIEW >> Find examples >> Search for VXI. They have several examples of how to write to registers. All you have to find out is what value to write that corresponds to 1000ns.
(2,695 Views)
