opc server
Dear Friends
I have used Labview for small tasks like serial communication, TCP/IP communication and building some graphical interfaces. At the moment, I have to develop an application which involves OPC server. As a newbie to opc server, I have watched couple of webcasts and read some stuff related to opc server. But frankly speaking I couldnt understand the following things in a possible scenario
Scenario
PC A: Labview installed and running OPC server
PC B: Generating some results based on the main hardware
Hardware: Receiving and sending signals from the handheld device like joystick
1)The communication medium used will be ethernet cable and do all of the systems need to be on same domain or work group?
2)How PCB and hardware can find OPC server as they themself are clients.
  I would be very greatful if you guys refer me some tutorials or pdf's which can help me in understanding opc servers.
Regards
Imran
(3,292 Views)
Hi arrowminds,
>Yes, all systems needs to be in same network/domain
>When you connect the hardware in the network and run the following example VI, it will show you all the available servers.
..National Instruments\LabVIEW 2009\examples\comm\opc.llb\Browse To OPC Item.vi
Hope this helps.
Regards
Santosh
(3,272 Views)
I have studied more about opc server and found that opc server needs to be installed on hardware and the PC needs to have Labview DSC.
Infact I am thinking of having real time target module of national instruments which will talk with my hardware. So in this case, can you help me where should be opc server and client.
And how I can National Instruments Real Time target module will find my hardware I/O ports which are having digi serial connector of (Digi Ports 16/EM).
This Digi Ports 16/EM is serial expander having a different kind of connector for output. I will also try to find out connector name.
(3,261 Views)
Hi Arrowminds,
Could you explain your question. What do you mean by "where should be opc server and client"
Did you find the name of the connector? Do you have drivers for the hardware?
Kind Regards,
Owen.S
(3,228 Views)
