op amp input
I need a simple summing amp to output varying 0.1VAC to 4.5VAC with a -7.5VDC bias.
I looked up some information on the web and built a 741 summing amp. My problem is that the AC loses about 0.5 volt at the output. I expect 1/1 gain with a little loss, but not that bad. Then I replaced the 2-6 10K feedback with a trimmer. When I set the feedback away from 10K, the VAC basically goes away. I expected setting FB >10K would increase my output AC and DC.
Any ideas what I am doing wrong?
Jim
741 opamp
+12VDC on 7, -12VDC on 4
4.5AC 10K 10K FB (tried a pot here, also to inc gain)
7.5DC 10K |2|\ |
| \ 6 | 100K
3| / |
Message 1 of 9
(4,657 Views)
My problem with this is that I did not have enough power supply voltage. It was clipping when I increased the gain.
Message 2 of 9
(4,657 Views)
Attach your VI so that we can work on it
Message 3 of 9
(4,205 Views)
Jay,
Why bump a 9.5 year old resolved offtopic post?
"Should be" isn't "Is" -Jay
Message 4 of 9
(4,201 Views)
Jeff Bohrer,
                Hahahah. Sorry I was looking for a VI on OP- AMP circuits. Did not take care about the date. Do you have a working VI o OP-AMP 741
Message 5 of 9
(4,199 Views)
OK What do you want the VI to do?  VI= Virtual Instrument,  the 741 is hardware that has no IO for software to control.
-Very confused
Message 6 of 9
(4,194 Views)
Sir,
     I want to use OP-AMP in its basic applications. I want to use it as an amplifier, iventer, adder, Subtractor, Schmitt Trigger, and other basic applications which u come across durig your undergrad course.
Do you have any such VIs related to Op-Amp,diodes,transistor,IC 555 etc
Jay
Message 7 of 9
(4,191 Views)
It sounds like you need Multisim. LabVIEW is a programming language - not a circuit emulator.
Message 8 of 9
(4,189 Views)
No No. I need it on LabView.. I need to implement on LabView. I am aiming to develop an educational tool for my college to help students. MultiSim is easy wherein the functions and working of each too is pre metioned. I want students to understand the basic concepts like even from formula point of view.
Message 9 of 9
(4,184 Views)
