only network browse using window explorer or other
when path control press or browse windows explorer open.
My computer ,desktop and network display.But i want to only network is accessible.
my computer and desktop is disable or not display.
(2,412 Views)
find attached screenshot for clarification of problem.
(2,404 Views)
I'm not 100% certain I know what you are asking, but I think you want to restrict the Path "Browse" button to a certain Path, possibly on the Network.
Right-click the Control on the Front Panel and choose "Browse Options".  Put the place where you want the Browse to start in "Start Path".  Note, however, that you still get Windows Explorer, and can still Browse to other places (I wasn't sure of that, myself, but just "did the experiment", and haven't yet figured out how to be more restrictive ...).
A good question -- I'll be interested if someone else has a better idea ...
I can think of a "post hoc" method -- you could start the user where you want, pop up a message that "Only files from here will be accepted", then test the path that is returned, and if it doesn't meet your restriction, reject the path and force the User to "try again" ...
(2,372 Views)
