one icon needed when running Labview
HI ,
I built an Labview Application ( .exe ) but when I try running it I see two icons in my windows tray. What settings do I need to do in order to get only one icon.
--A
(3,474 Views)
Add the following line to your 'exename'.ini file:
hideRootWindow=True
(3,474 Views)
The ini file was empty so I added the line as you had mentioned but it still didnt work...
-A
(3,474 Views)
That's one of the most frequently asked questions around here. Searching here for HideRootWindow should produce many links to check out. Also refer to http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/f9d39ef27ce50fae8625667b0003fa0c?OpenDocument in the NI knowledgebase (ID# 1D8IMNW1)
(3,474 Views)
above that line, you need another line:
[NAME] where NAME is the name of the NAME.exe that you are running
tcphan
(3,474 Views)
