one dialog button
I press the ok button of the one dialog button but it doesn't disappear from the screen. I tried to add a delay (such as wait until next multiple) but the message disappears instandly and appears again. I tried to increase the delay however the problem doesn't fixed. And one question: I suppose that the function of the one dialog button is to block the vi execution until the ok button is being pressed. Am I correct? I would appreciate any possible help.
Thanks in advance
Message 1 of 20
(3,870 Views)
Can you attach your vi? i have a suspicion i want to check on that.....
Norbert
Norbert
Expert: Geometry
Message 2 of 20
(3,867 Views)
Hi thorfano,
do you call this dialog in a loop? Can you show your code? Yes, with this function you can block the vi execution.
Mike
Message 3 of 20
(3,867 Views)
Yes, until you press 'OK' button the vi is on halt. And about you question attach your VI or its snapshot. I did not get your problem.Smiley Surprised
I have still not got what I love.....
Message 4 of 20
(3,864 Views)
Thanks a lot. Yes I use a while loop and I attach a simple example of my problem.
Message 5 of 20
(3,857 Views)
But u missed your attachment.... Smiley Surprised
Mathan
Message 6 of 20
(3,844 Views)
Sorry but obviously I am missing something in the attachment procedure. I go to the attachment and select my vi. Where I am wrong?
Message 7 of 20
(3,834 Views)
Sorry, but I am missing something with the vi attachment procedure. I use the browse button to select the vi but I can't find the attach button. Could you be so kind to help me?
Message 8 of 20
(3,823 Views)
When you reply to a message, there is an area called "attachements" below the text box. You cannot attach any type of files to this forum, but .zip and .vi are legal fileextensions.
Please note that the preview function is said to discard any attachments of your post.....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 9 of 20
(3,818 Views)
Thanks a lot. I think that the problem was that I used the "Preview post button". I am trying again.
Message 10 of 20
(3,815 Views)
