on/off boolean
That work great. Thanks!
here's another question.
once the emergency button is push. How do I get the On/Off push button to reset?
Message 11 of 13
(746 Views)
Which technique did you use? If you used the simplest method which is just a stop or cancel button from the palette, it will return to the false state as soon as it's read and the while loop stops. Check the mechanical action. The default for stop/cancel is Latch when Released as I mentioned earlier.
Message 12 of 13
(742 Views)
Thanks that was a great lesson today.
Message 13 of 13
(737 Views)
