omega flowmeter sensor daq connection
Ok, i created it now.What should i do?
Regards
Message 11 of 15
(1,442 Views)
Now you can wire your sensor in the same way as MAX shows you.
Then you can test your sensor using MAX.
Then you can create your VI using this DAQmx task or by calling the appropriate DAQmx functions…
Message 12 of 15
(1,438 Views)
But where does it say how the connection will be?
Message 13 of 15
(1,429 Views)
Accepted by topic author sgirgin
It shows it in the task configuration dialogue…
Message 14 of 15
(1,426 Views)
ahh i see now thank you
Message 15 of 15
(1,423 Views)
