ogic library error
Haven't a clue yet, other than trying to stick some delays in the LabVIEW code. Don't really know if that's the problem, and I don't know where they would go. I'll try to take a look at this tomorrow.
Message Edited by smercurio_fc on 06-26-2008 05:23 PM
Message 21 of 23
(694 Views)
when I ran the code in highlight mode, i receive: TCP Read in OGIC_SMTP_SendCommand.vi > OGIC_SMTP_Main.vi and i don't receive the email...
The error is only in QUIT command...
any clue?
thanks
Message 22 of 23
(680 Views)
I did a little playing around with this this morning. As far as I can tell you need to insert a small delay before executing the QUIT command. I inserted a 2 second delay between the step that sends the attachments and the step that sends the QUIT command. Each time the message was sent and I received it. I do not know what the minimum time is, as I believe this will depend on a number of factors. Try inserting a delay there and see what happens.
Message 23 of 23
(667 Views)
