off digital IO after press stop button
This works well.
I'm curious if TWO digital line need to stop simultaneouly while pressing ONE stop button only,
I try to change the DAQmx write where Digital>multiple channel> single sample>1D Boonlean
when i wire the constant true to data line of the DAQ mx write, theres error there.. Am i missing something? appreciate if you can check this.
Message 11 of 16
(976 Views)
@JohnS11 wrote:
This works well.
Well if you want to write multiple dig.lines at the same time you need to give the value for each line, so a 1D array of boolean, one element per line.
Epictetus
Antoine Chalons
Message 12 of 16
(969 Views)
Hi Titou,
Previously, after run your vi, the digital IO will be off after press the stop button. this is a wonderful vi.
what i plan to do as follow....(Replace the stop button with a reading from analog input)
when analog input read a voltage less than 0.5 volt, the indicator will change, and it will off the digital IO..
whats wrong with it? it can't work..help to correct it. Thanks.
Message 13 of 16
(958 Views)
In short, How to replace the "manually press stop button inside the event structure" with "analog input read voltage less than a value then true"?
Message 14 of 16
(933 Views)
This may not be exactly what you need but it should help you to get there, here's a VI based on one of the examples that comes with LabVIEW :
If you give more details on what you application is, we can then adapt this VI to do what you want.
Feel free to ask any question if you're not clear with how it works.
Hope this helps
Epictetus
Antoine Chalons
Message 15 of 16
(930 Views)
oooops... here it is in LV2009.
Epictetus
Antoine Chalons
Message 16 of 16
(929 Views)
