octave function strmatch unimplemented error
hello forum, i am trying to use labview with octave,i have a .m script that contains strmatch but i get the error: feval: function `unimplemented' not found...
this what i write
list = {'max', 'minimax', 'maximum','max'};
strmatch('max',list)
when i try to do it from the octave command terminal,it works right,,,,why would strmatch give an error if called from a script?thank you
(3,087 Views)
are you using GNU Octave LabVIEW example or LabVIEW Mathscript Node?
What version of LabVIEW are you using?
You can try to use strmatchall function.
I hope this helps!
Bye,
Licia
(3,066 Views)
thank you..let me try that
(3,059 Views)
