ocr examples
hello,
i have trying using the ocr's in the example platform,they are very nice but they work with .abc files only,is there any way to elaberate thier use to true type fonts ?
Message 1 of 9
(8,487 Views)
@Shal wrote:
hello,
OCR is trainable. That's why the abc files that are used in the examples match to the images used in these examples.
If you want to ocr true type fonts, you should create your own abc files with the OCR Training Interface that ships with the NI Vision Development Module.
Message 2 of 9
(8,479 Views)
so the question is how to convert true type fonts into .abc file? if such a convert exsit at all.
Message 3 of 9
(8,472 Views)
As far as I know there is no converter available.  That's why you will need to train the characters.
Message 4 of 9
(8,469 Views)
Not a bad idea! We should make one!
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
Message 5 of 9
(8,452 Views)
I gave the converter a shot. Hopefully this will help you out!
Message 6 of 9
(8,427 Views)
hello,
first of all thanks you all for your kind answers,it really helped.
i have few more questions:
1. i have train the charcters and created one .abc file which is gathered few true type fonts in it.
    the problem that accured was collision in the interpation,for example : between 8 to B or between l to 1.
   is there any way to improve the ocr accuracy so such collisioins wont occurre?
2. if i use few .abc files,how do i know which is the most ideal .abc file from all of them?
3. regarding to Alex T fonttoabc convertor- i have tried using this convertor with fonts im using (digital fonts) it created    an abc file,but the interpation wasn't good. any suggestions?
Message 7 of 9
(8,352 Views)
I opened up the .abc file it generated and... well...
That doesn't look too good. Smiley Embarassed I'll try to work some more on it!
Message 8 of 9
(8,347 Views)
Fixed! Please give it a shot!
And the result?
Message 9 of 9
(8,336 Views)
