obtaining default DIRECTORY
seems trivial but am having a hard time with it.
I need to strip out a default DIRECTORY (not default drive)
from a file name (which includes path).
There is no way for me to know apriori what the
path directory or file name will be, or how many
levels below the drive the file name will reside.
For example: the name might be d:\xxx\yyy\zzz.spc
or it might be d:\zzz.spc.
In the first case, I need to be able to strip out to get
d:\xxx\yyy\ and in the second case, I need to strip
out to be able to get d:\
It is not obvious to me what pattern to search for since
I don't have any clue as to what the file name or path
will be beforehand. Have any ideas?
(3,054 Views)
Use the function "Strip path". This returns the full path minus the
last item. It does not care how many levels it takes. But of course
you have to send it the full path to begin with.
At least I think this is what you are asking.
Kevin Kent
(3,054 Views)
Under the Functions Palette/File I/O, use the strip path function. It
returns the stripped path and the last component.
(3,054 Views)
