obtain a timestamp from database connectivity toolkit
hello!
I would like to get a timestamp with the database connectivity toolkit.
from sqlserver, my datetime is written like this:
format: datetime
content: 2016-01-01 00:00:00.000
The VI I'm using looks like this:
the typedef cluster entering into the function "database variant to data" has the properties below
but when I'm launching it, the function " the function "database variant to data" returns this error, translation "datatype in the variant is incompatible with the datatype at the input of the function
I f I edit my typedef and replace string from datetime, everithing is working, the boleans return the correct values, but  time returned in the string is just date, not time.
can you help me?
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(4,306 Views)
It seems the datatype datatime is not a string, it's a specific datatype for LabVIEW.
In my point of view, you have to use a function to convert the datatime in tring and send a string to the database (see example bellow)
String is a classing datatype easily shared by different programming language.
If you want to change the parameter of the time in the string, refer to the help of the function.
Best Regards,
Guillaume D
(4,229 Views)
The datatypes need to match exactly or they will not cast correctly.
You could use this scripting VI I wrote some time ago to have LabVIEW create a cluster for you based on the elements of a specified table.
You can save the cluster as a typedef and then use that the create an empty array to use as the input to the Database Variant to Data function.
https://decibel.ni.com/content/docs/DOC-19512
 You may find that the datetime is being stored in your DB as a string, which means you would need to convert it yourself from string to datetime.
(4,219 Views)
