numeric series
Is there any function which gives a summarized serie from a selected range?
For example, in my bluetooth test, I can measure channels from 0 to 78. I select, for instance, 0, 2, 10, 11, 12, 13, 14, 15, 20, 21, 22, 23, 24, 25, 30.
                                                    In the summary, I would like to get a more compact view, like: 0, 2, 10-15, 20-25, 30
Thanks in advance.
Gatet
(3,268 Views)
hi Gatet
I havn't found any function that performs the requested operation !!
Why don't you build  it?
Possible solution ==>pseudo code
1:string data to array
2:use a for loop to index  an array (True /false ), shift registers to hold salient data
3:extract salient data from true/false data with respect to string data array.Decimate  all non essential cells
4 reverse process- array to string
Should give you some ideasSmiley Indifferent
chow
xseadog
(3,264 Views)
Sorry, Chow, but I don´t understand step three. WOuld you be so kind to explain it a bit?
(3,261 Views)
Hi Gatet
vi produces T/F Array
Now you have to link array data with string array data to finish with a sequence.
NB: in present form it produces a false 'true'on hte last  cell (comparision)
hope that sets you on your way
chow
XSEADOG
(3,249 Views)
Here is the solution!
Thanks for your help, Chow
Mensaje editado por Gatet
(3,242 Views)
It was not correct for only one value selection, and also not with the first selection.
Now is better
(3,222 Views)
