numeric indicators to smart array
Hi guys, I have numeric indicators, which read satelite number and C/N from GPS sentense.
I need move this indicators to some cluster or something. Satellites with 0dB i need make gray and disable.
There is pdf and vi's. This is subVI.
Message 1 of 12
(5,423 Views)
For this you can use the Disabled property and set the input to Disabled and Grayed out if the indicator is equal to 0xDB
http://zone.ni.com/reference/en-XX/help/371361L-01/lvprop/ctrl_disabled/
You're going to have to give us more information here.  Why do you think you need to cluster these elements?  What is the end goal of doing this?  What do you want to do with your applicaion that you cannot currently do?
Message 2 of 12
(5,400 Views)
Could you please explain in a little more detail what you want to do?
Message 3 of 12
(5,392 Views)
Hi. I try explain it.
I have much numeric ingicators like satelit č (satellite number) and S/Š (C/N). I need make from this indicators one smart indicator. Which know hide C/N and satellite with no signal (0 dB).
Message 4 of 12
(5,329 Views)
Hi, could you explain a little bit better what you mean bu smart indicator please.
Message 5 of 12
(5,299 Views)
Something like this. Indicators in array.
Message 6 of 12
(5,264 Views)
It seems like to want an array of clusters.  I'm still not totally clear what you're going for though.
Message 7 of 12
(5,248 Views)
I just need get indicators to some group and conect it to panel (icon)
Message 8 of 12
(5,128 Views)
Hi, why do you want to implement your indicators in this way, what is the main goal of your applications, beacause maybe we can use something different to achieve the same thing.
Message 9 of 12
(5,075 Views)
U bundle it in aray. Pin on terminl aray, and working with it. It's done..
Message 10 of 12
(5,049 Views)
