number array to spreadsheet string
Dear All,
I'm having problems converting a number array to a spreadsheet string with one decimal precision. The number array is quite long (>1000 elements). When I save the converted spreadsheet string (plus some text) to a txt-file and try to open it with Notepad, the opened file looks like the attachment. The file opens with Wordpad in correct form (see attachment). For saving I'm using Write to Text File -function.
I have also attached a picture of the subVI which converts the number array to spreadsheet string. Interestingly the saved file opens correctly when format string is set to %f.
I'm using LV8.5.
Markus
Message 1 of 11
(5,964 Views)
Hi Markus,
where is the problem if it works with %f? "f" is correct for floating point numbers.
Mike
Message 2 of 11
(5,960 Views)
This is expected. %.1f you have already used. What is the prob?
Message 3 of 11
(5,938 Views)
Hi Mike,
It works with "%f" but not with "%.1f". I would like to have precision of one digit after the decimal point. I have understood that "%.1f" would be the correct notation but when using that notation the resulting txt-file looks like the attachment.
Thank you for your reply,
Markus
Message 4 of 11
(5,934 Views)
Message 5 of 11
(5,920 Views)
Hi Markus,
for me it also works like shown in muks picture.
Mike
Message 6 of 11
(5,909 Views)
Thank you both for your answers,
I removed all the other stuff and left only Array to Spreadsheet String -function in my subVI and it worked too. I was thinking that could the problem lie in End of Line constants which Notepad would not recognise.
Markus
Message 7 of 11
(5,894 Views)
I feel the problem might be the value you get into the array.
Message 8 of 11
(5,893 Views)
Even with 0.1f, i am able to get the file working properly with Notepad.
I built the code in LabVIEW 8.6 with the screenshot you have attached.
Sundar Ganesh
Message 9 of 11
(5,892 Views)
I dont think so it is because of that.
Message 10 of 11
(5,884 Views)
