not a valid labview file??
hi,
when i was trying to save my vi, it gave an error like;
LabView end of file encountered.
The file xxx.vi is not a valid LabView file.
the last command i added was a "current vi's path"
normally it was a 350kb file but now it is just 1kb!
what happened to my vi?
thanks.
(2,599 Views)
It seems your VI has been corrupted. This may have been a LabVIEW error, or a disk file I/O error. You will need to revert to a backup. You should also do a disk scan to rule out any problems with the disk.
(2,593 Views)
