12-14-2010 10:35 AM
Right, I have a program in two parts. The first generates a sine wave and outputs it to an external device. The second part takes a camera input and runs some calculations on the data and outputs it in a speadsheet.
The problem I have is that the data is not recorded with the frame rate of the camera (17fps) but at the loop rate of the first while loop (10 per second). When I run the camera part of the program seperately I get the full 17 per second.
I would like both parts in one VI.
So my question is, how do I get the loops to run non-simultaneously?
I would include my VI but it has a lot of complicated functions which won't back any sense, but I think my question is quite general. Any more details I will be happy to give.
Thanks to anyone who can give me some advice on this.
James
Solved! Go to Solution.
12-14-2010 10:45 AM - edited 12-14-2010 10:48 AM
Two separate parallel loops should run independent and simultaneous if there is not any dependence between the two.
Without seeing your code it is hard to tell what the problem is.
Any queues or notices between the two?
Do the two loops share any non reentrant sub VI's?
Are they talking to the same hardware device?
Reading from or writing to the same file?
These are just same of the thinks that could effect loop timing.
12-14-2010
10:46 AM
- last edited on
10-24-2025
06:53 PM
by
Content Cleaner
You probably want this:
It is a standard producer/consumer model.
A
12-14-2010 11:49 AM
Right, I think the problems stems from a simple processing power limitation.
When either part of the program run the processor is at around 85%. I am saving the data from a line of pixels of about 500, finding peaks in the intensity, and uses the spacing between these peaks to obtain another value which I write to file.
The computer I have is a single core P4 3Ghz, which I would have thought would be sufficient.
12-14-2010
01:45 PM
- last edited on
10-24-2025
06:54 PM
by
Content Cleaner
Ok, you have 2 loops. Loop 1 reads data once every 10ms, loop 2 every 5.88ms. These are independent, so you don't want the camera data to be going out every 10ms but at the faster rate of 5.88ms. Sounds like you want them to run asynchronously but in the same VI.
If this VI is not a SubVI (not called by another), I see no problem in just putting two loops side by side (not nested) and have them run. To stop each loop, have a stop button that is referenced by both loops to allow for termination of both of them.
parallel loops
Each loop can be a SubVI that contains a loop, but then to terminate each, you would need a common refnum to a control to be able to terminate each at about the same time.
For more information check out http://zone.ni.com/devzone/cda/tut/p/id/9393.
If each part of the programme caused it to go to 85%, then yeah, you are going to run into problems. Try reducing the CPU load by decimating the data and/or reducing the number of events being fired in the system. LV 7 was crap with such high number of event hits, I dunno if this has improved in the more recient versions.
A
12-15-2010 06:38 AM
Right, the thing limiting appears to be the method of writing data to a file. I was outputting as a spreadsheet but it runs faster if I output as string data to a text file.
This increases my write speed to around 24 per second, which will be sufficient until I can convince my boss I need a faster computer!
Just another quick question, will Labview 8.2 utilise 2 cores in a multicore processor when running a program with parallel while loops?
12-15-2010 06:38 AM
And thank you for your help!
12-15-2010
10:14 AM
- last edited on
10-24-2025
06:54 PM
by
Content Cleaner
Short answer, yes. For more info try looking at this:
https://www.ni.com/en/shop/labview/multicore-programming-with-ni-labview.html
A
12-15-2010 10:55 AM
Just an addition:
Storing data to a file in very short parts is not a question of faster or slower computers, but is a bad design.
What I would do is adding up some much longer chunks of data, put it into a queue and write that much bigger chunks less frequently in an independent loop.
Some background:
Harddisks can store some 10-60 MB/s when streaming (writing continuous chunks of data into continuous rooms on the disk). This can be improved by far by HD's internal caches, as the OS copies data into that cache and the HD takes care of it. BUT the process of copying takes some time ( parts or multiples of ms) in itself, that is allmost independent on the size of the data chunk (as long as it short ~ Bytes to kB). And than there's a minimal storage block for most storage devices, a sector, of size of 512B ... some multiples thereof. So writing in smaller chunks effectively means rewriting data until a complete sector is filled and the next ist used.
If you really try to rely on brute force, use a faster HD, an SSD or a RAID array with several physical HDs and a large cache. But again, writing larger data chunks (optimal in size of complete clusters or even much bigger) less frequently would help much better. This buffering can, however, bring the not-yet-saved dat at risk if your PC crashes. Keep that in mind!
Just my € 0.02!
Greetings from Germany!
Uwe
12-16-2010 02:31 AM - edited 12-16-2010 02:35 AM
How do I do that, adding data to a queue? At the moment the data is written after each loop iteration - is there a simple way to simple store the data in a buffer and write it all every 10 loops for example?
