non linear curve fitting from lvm file
I am currently trying to get the fitting equation from a set of data (x and y) in lvm file. I am using the curve fitting vi under mathematics > fitting.
I am using the nonlinear fitting function of this vi and the equation is as follow:
y = a-0.15*2-b/x-c*x+d*ln(x)+e*ln(1-x)
however whenever i try to run the program, it shows an error pointing to the curve fitting vi stating this:
Analysis:  Input parameters has at least one element that is Inf, NaN, DBL_MAX, or DBL_MIN
what could be the problem?
atoz
(3,646 Views)
Hard to tell from the information given.
Can you attach your VI?
Is one of the x values zero? You have a division by x, so that would result into a NaN.
Do you use reasonable guesses for the 5 parameters?
(3,640 Views)
Thanks for the quick response. This attachment are the vi and the lvm file from measurement i have. I do not have a point which is exactly zero. I am not too sure about the initial guess as well.
atoz
(3,636 Views)
  • Well, the last value is x=0, so 1/x will fail.
  • A lot of points at the beginning are x>1, so ln(1-x) will be undefined too.
I haven't looked in detail at your function, but it seems insufficient to describe the data. Can you point me to a website describing the model in more detail?
(3,629 Views)
Thanks for the reply.
Actually the function is taken from a research paper on a Kalman Filter for battery state-of-charge estimation. it is describing the battery terminal voltage interm of the state-of-charge.
atoz
(3,622 Views)
Do you have a link to the research paper?
(3,599 Views)
