node not supported in current target
hi,
i was doing some testing regarding subvi's using labview and i came across this problem. when i created a subvi with an indicator attached to it and try to download it to my NXT, it says that the node is not supported in current target. Does somebody know how to solve this problem? i am using labview 2009 with NXT toolkit. Attached is the picture of the error i encountered
thanks
(5,701 Views)
I don't think NXT supports reference, since it's not available in function palette.
(5,673 Views)
thanks for your reply.
so how do you suggest i should go about to use an indicator for a subvi?
(5,668 Views)
Why won't wiring an output from the subVI work? That's the normal way to do it? Why do you want to use a  reference? What is the code in the subVI?
(5,660 Views)
this is the vi i would like to turn it into a subvi. how do i do it when i have indicators within loops? can you show me how to turn it into a subvi?
thanks
(5,629 Views)
