no block diagram during debugging application
Hello friends,
I'd like to debug a running application.
I'm able to connect to the application with the "debug application tool" of LabView and I can see the frontpanel of all running applications. But I'm not able to open the block diagram. The shortcut "ctrl+E" doesn't work and because I use a custom run time menu there's no menu entry to open the block diagram.
By the way: I tried to include the LabView menu entry "debug application" to my custom run time menu but I could not see the entry in my application. Is this a bug?
Thanks for help.
Ronny
Message 1 of 11
(3,985 Views)
Hi
"Show Block Diagram" Menu will not appear in the exe of LabVIEW application, because LabVIEW removes the BlockDiagram during formation of Executable.
go through Documentation for more details
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
Message 2 of 11
(3,968 Views)
Thanks for answering.
I think it's not really true that LabView removes the block diagram. If I check the option to be able to debug the application then it should be possible to see the block diagram. The manual says that I can use the same debugging techniques that I use during debugging the code in LabView including block diagrams.
Ronny
Message 3 of 11
(3,963 Views)
Hi Ronny,
I think with "Debug applicaiton tool" you mean one of our new features in LabVIEW 8 to debug applicaitons and dlls. When you build the applciaiton you cann choose under Advanced "Enable debugging".
Have you choose it?
Rebecca Fox
Message 4 of 11
(3,947 Views)
Yes, I did.
I've choosen "Enable debugging". I could see that the size of the application doubled. I think that means that the block diagrams are still in the code.
The I used "debugg apllication..." at the project menu and connected to the running applications. That worked so far. I saw the windows of the applications doubled - a local instance and a remotelly controlled one.
I think this is as it should be. But I could not open the Block diagram. The shortcut was not working and I could not see any "run time menu"-entry.
Ronny
Message 5 of 11
(3,936 Views)
Hi Ronny,
ok I tried it several times in LV 8 and it´s working...so we should look if there is a "problem" in  your project. Please make a very simple VI with a Random Number and show it in Frontpanel. Put this code into a While Loop. Make an applicaiton of it and try it with this one. When this is not running then install LV new, when it´s running then you should minimze your code and attach it in forum so that I cna try it.
Rebecca Fox
Message 6 of 11
(3,935 Views)
I did what you told me to do - and it worked. I was able to debug the little program.
Whats the problem?
Perhabs this: The program that I can not debug was converted from LV7.1. Perhabs something failed during the convertion from the *.bld-file to the project file.
Could it be? (I don't want to created a new project again with about 300 VI's:-) )
Ronny
Message 7 of 11
(3,914 Views)
Hi Ronny,
a few days ago I get a VI from a customer which has the same problem. We found that he is using VI Server and that he is working with actual path. We think that there is a problem with it and forward it to developer. I think you should minimize your VI step by step to find the problem in your project! Than you can post it in forum so that I can have a look on it.
Rebecca Fox
Message 8 of 11
(3,911 Views)
I use the VI server, too.
What means "actual path"? Does it mean that he uses a path to open a VI refence instead of a the name string of the VI?
If this is the case why is it not possible to debug this?
What do I have toi change in my code to enable debugging?
Thanks for your help!!!!!
Ronny
Message 9 of 11
(3,903 Views)
It´s only a speculation that this can cause the problem. In LabVIEW there is a constant for Current VI´s Path when using this I´m thinking that LabVIEW gets a problem. When you make VI Server in a SubVI delte it and copy code into Main VI. When this is not helping then it´s necessary that you minimze your VI to find in which VI the problem is and where connection failed.
Rebecca Fox
Message 10 of 11
(3,900 Views)
