no VXI-11 LAN/LXI instruments were found in local subnet
Hey, I need to built communication with Adam6066 via modbus,with the modbus lib. I can get the register value when I run MB Ethernet Example Master/vi/. However, I cannot find this Adam6066 module in the Measurement Automation Explorer.it could be detected. but it does exist in the LAN, and I do can get the data from its register.so, how can I imprver it/ I attached the screenshot. hope someone can give me a help
cheers!
(4,008 Views)
Your adam is not a VXI-11/LXI instrument so it would not be detected. I'm not sure why you even tried this.
(3,986 Views)
I got the solution,~~only need to define the IP address~~sorry, im new beginner~now I get results from the modules
(3,974 Views)
