nidaq opc
Hi all,
At present if i go onto a PC with Labview 8.5 professional installed and create an OPC client against the National Instruments Variable Engine, i can see all the Daqmx channels set up in the MAX software.
However if i install the drivers and MAX software onto another PC, along with the run time files for Labview and i create Daqmx channels in the MAX software there and then connect to the Variable Manager, i see nothing?
Is there something i am missing when setting this up on a PC which doesnt have the full version of LabVIEW installed, instead just the run time files?
Just cant get my head round it 😞
Thanks for any help
Mike
(2,589 Views)
Hi Mike,
NI-DAQmx installs the shared variable engine and an OPC server without having to install LabVIEW. Try modifying your NI-DAQmx installation from Add/Remove programs and check if OPC/variable support is checked.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,565 Views)
Many thanks, i checked a few options regarding opc and its fine now
ta
Mike
(2,555 Views)
