niSwitch Initialize.vi
Where can i find following Sub VIs
1.niSwitch Initialize.vi
2.niSwitch control a single Switch.vi
(2,894 Views)
Hello testdev.
The niSwitch Initialize VI can be found in the NI-SWITCH functions palette which is under the Measurement I/O palette heading on the functions palette.  The VI's that control a single switch are the niSwitch Connect Channels VI and the niSwitch Disconnect Channels VI which are also located on the first level of the NI-SWITCH functions palette.
Please keep in mind that you must install the NI-SWITCH driver to see these VI's.  This driver can be downloaded for free at:
NI-Switch Version 3.4 for Real-Time OS/Windows 2000/XP
Let us know if you have any other questions on this issue.  We will be happy to help.
Brian F
(2,864 Views)
