niFgen initialize giving error code -1074135030
Hi everyone,
I am trying to use niFgen Initialize.vi and when my vi runs it produces the pop up error along the lines of "Cannot find nijelu.dll" and then throws the error code -1074135030 in the niFgen Initialize vi.  It reads "niFgen Initialize.vi<ERR>Failure loading driver module."  I checked in max and my device reads properly, I have a PXI system using the NI-PXI6133 card.  Labview is version 8.5.  Any ideas?
KC
(2,813 Views)
Hi KC,
After searching other customer issues, the best explanation would be a driver installation error.  You said you were using LabVIEW 8.5, but what version of NI-FGEN are you using?  You may need to uninstall and reinstall the driver by going to Add/Remove Programs in your control panel or even download the newest version  of NI-FGEN (2.5) from this link.  There were other errors associated with loading nijelu.dll due to the NI-TClk driver which installs with NI-FGEN.  This again should be fixed by upgrading to a new driver.  Please let me know if this information is helpful!
Vanessa L.
(2,782 Views)
