niDigital Load Pattern Error -1074099243
I'm trying to run some code that was successfully developed on LabVIEW 2019 using an updated install of LabVIEW 2023Q1. The code that used to work properly now gives me Error -1074099243 when I try to call the niDigital Load Pattern VI. The error explanation says the specified instrument index is invalid and gives the instrument index value as -1. However, I don't see the instrument index as a parameter anywhere in either my digital pattern files or in the niDigital VI palette or property nodes. If I launch the digital pattern editor and run the patterns from within that utility, the patterns load properly, and I observe the expected signal outputs. Is this issue caused by the update from 2019 to 2023Q1? I've tried re-saving the project using the digital pattern editor, but that doesn't seem to help with this issue.
Any advice will be greatly appreciated.
Message 1 of 1
(1,285 Views)
