ni9133 linux embedded change font size on front panel
dear community
Nice to greet you, and I hope you can help me with this problem that is generating more than one headache.
I have an embedded system in linux ni9133
and the programming environment I am using labview windows 2016
the problem is generated when I make the program with its corresponding font sizes. When compiling the program, transferring it and running it on the 9133 chassis, the font size and style are loaded correctly and it only stays at size 15. (I have changed the font size from the front panel and invoke node size font, and it still doesn't work).
when I load the program remotely, the font sizes and styles are not loaded either.
I am new to working with types of embedded systems, even more so with linux.
Could you help me how I can make this modification, since it is urgent for me to be able to do it.
I appreciate your help in advance.
Thank you so much
Message 1 of 1
(963 Views)
