ni scope trigger first with digital and continue with software
I programmed a measuring loop and it works with an immediate Trigger. Now I started with an digital trigger an it also works, but make only the first measurement. So I use the send software trigger edge but it wont work.  Does anybody know how to solve it? In the attachment I send a pictures of my measuring loop.
(1,596 Views)
Hello Christian,
Can you try to take the "NI Scope Multi Fetch.VI" out of the case structure and try to make the acquisition again? I'm not completely sure but it is possible that it also affects doing measurements.
Regards.
(1,539 Views)
I tried this before I made the case solution. Now my solution is to do a single 1s measurment where it waits on the trigger and in the 2nd step I am starting the "real" measurment.
(1,524 Views)
