ni hypertrend with opc data socket
hello,
i am going to use ni hypertren with labview dsc 8.6 version. i am not using shared variable here but using opc server + data socket i am reading all the channels of data. currently i am reading 300 channels of data over modbus tcp/ip network. all are thermocouple inputs and each module has an 8 channels of array of data which i defined, i tried using shared variable but here i need to create 300 variable for each channel then only i can able to insert these data values to the data base. but using data socket with opc server i can able to group it 8 channels/ module the i can able readuce my data set also it will be traceble one. to inserting data base i am making programming.
i checked the ni-hypertrend, i gone through the help, my question is can i plot the datas from opc data socket with out using shared variable...?
Balaji DP
Message 1 of 1
(2,312 Views)
