ni goop 32bit installs in 64bit labview
I have both LabVIEW 2014 f1 versions installed on same machine (x32 and x64). I have downloaded NI GOOP v.4 which has both installations (x32 and x64). I expected that each would install itself in its "native" LV environment. However, the 32bit version installed in the 64bit LV (..\Program Files\.. insetyad of ..\Program FIoles (x86)).
Is this a bug? It seems immpossible to install NI GOOP in 64bit WinOS?
How can I install the 32bit version in the corresponding (x86) folder?
Thanks in advance,
(3,043 Views)
Hi golubovski,
I noticed that you posted over in the GDS community as well (https://decibel.ni.com/content/message/86509#86509), did they answer your question and do you still need help?
Brian H. -- Electronics & Measurements Product Marketing Manager
(3,001 Views)
Brian,
Thank you for responding! Yes, Mikael did respond and helped me firn the uninstall option. However, since there are lefovers in the LV foldr structure, I decided to recover my recent Acronis image 🙂
I still think the x32/x64 installation decision does not have anything to do with the GGOP vs. LV version compatibility - the x32 installer should recognize x64 OS and look for the x86 "program files" folder...
R
(2,990 Views)
