newbie guestion
hi! i am totally new to LabView and beforehand i am sorry for a silly
question, but i have not found anywhere answer and now ii don't know any
more where to search...:(
essence of a problem in the following: how can i set with LabView a
constant voltage level on one of analog outputs? the most simple way would
be place LabView Update AO Channel function in While Loop, but i'd like my
program solves also the primal problem:) Whether it's possible to make not
using any loops? i feel it possible!:-)
i'm beforehand grateful for the answer.
Igor Bljahhin
Faculty of Physic, University of Tartu, Estonia
mailto:igor@ut.ee
http://www.physic.ut.ee/~igor
Origin #346:
Horosha lozhka pri lovle bloh.
(2,925 Views)
In article ,
It will hold the value until you write a new one to it. So, just write it
once, and it will work. Even after you close the vi, unless you open
another one w
hich references the same channel.
Harry
"Little Joe for the Big Heisman, '99"
(2,925 Views)
