new vision builder? and change settings
Hi All,
at this moment we use Vision Builder AI 2015f3 for inspecting a 'time abacus' (or simply a clock) to analyse the time displayed on this abacus.
This abacus has 6 columns, with each 9 LED's. the first column represents 100s (100-900), the second represents 10s (0-90 s), third 1-9, 4th 0,0 - 0,9s; 5th 0,00 to 0,09s and 6th 0,000 to 0,009 s.
Normally i use on 'detect object' to detect how much LED's in each seperate column are bright, but due to reasons i had to create "detect objects" for each seperate LED (so instead of 6 'detect objects' i now had 54).
If i need to change the settings (like "minimum object size) of all of these objects in one column, i need to do the same 9 times. Is there a way to do that all in once for all these 9 'detect objects'?
another question:
we can also use a clock that uses 7 segment displays for showing the time. this clock shows 1234,567 s
In VBAI 2015 it is possible to learn what each value is, to analyse the clock. I was wondering whether the latest version of VBAI would be somewhat better at it?
below two pictures
Abacus (clock old)Abacus (clock old)Clock (7 segment display)Clock (7 segment display)
Message 1 of 1
(595 Views)
