network variable error
Message Edité par julesjay le 03-06-2007 08:17 AM
Message 11 of 17
(1,675 Views)
Hi Rudi,
Yes I've still this problem.
I can also create a new project where it wortks fine.
But it has appared in my current project and cannot handle with it!
I've no idea what to try to correct this. I've got two Computer and the same problem occurs. So I think that something in my code provoke this.
Message 12 of 17
(1,674 Views)
Jules:
Thank you very much for getting back with me. Since starting from a new project does not return any errors, it is possible that your library in the current project is corrupted. Feel free to post your entire project so that I can look at it further.
Rudi N.
Message 13 of 17
(1,661 Views)
I've already thougth about a corrupted library. Then I've created a new one but there is the same pb.
Message 14 of 17
(1,649 Views)
Jules:
Could you please post the troublesome project files so that I can try them on my end since I am not able to reproduce the same issue?
Rudi N.
Message 15 of 17
(1,630 Views)
Hi Rudi,
My project is quite big !! It 's difficult with my mail to send big files.
Actually, I've found a way to avoid the problem. Instead of creating a new shared variable from the diagram, I use a drag and drop directly from the project  explorer to y diagram and it's works .
Thanks for your help
Message 16 of 17
(1,626 Views)
Jules:
I am glad it is working, please let me know if it does not turn out to be a viable solution.
Rudi N.
Message Edited by Rudi N on 03-14-2007 02:42 PM
Message 17 of 17
(1,619 Views)
