.net components on remote panel
I have created a VI which displays the contents of database on the .NET datagridview in labview8.5.
when i web publish this VI, the data on the datagridview is not displayed. i see blank datagridview although data might be present there.
i can still see the data on Labview front panel.
Does anyone know any solution to it?
Any help is appreciated.
thanks.
Dev
CLD Certified Engineer
(2,465 Views)
Hello Dev,
Can you post the vi you have developed. I earlier thought that there is some small error but after looking at your signature I realized its not the case Smiley Happy
If you can post it I will run the vi and will try to understand & solve the problem.
Hardik Asawa
(2,444 Views)
