nested loops
If you use nested loops to create a 2d array.  Which loop creates the rows and which loop creates columns?
(2,974 Views)
Do the experiment (write a double-nested loop, take the inner-most index and bring it out).  You'll see that the Outer loop gives you rows, the Inner loop gives you columns.
(2,970 Views)
