need to decimate data to 600 Hz sampling rate
Hi
I'm a little bit stuck and confused about a problem.
I have acquired data with a sampling rate of 5kHz. Now I need to reduce them down to 600Hz.
(I have saved the data in a tdms file.)
Is there an easy way to do it? I tried the express vi "sample compression" but you can't set 8 1/3 as a reduction factor.
Of course another easy way would have been to acquire the data with a reduced sampling rate but unfortunately the NI 9237 module needs a minimum sampling rate of 15xx Hz.
Thanks for any help
Yves
(3,344 Views)
You can try to use Resample Waveforms vi (with a factor of 3) and then use the sample compression with a reduction factor of 25.
Ben64
(3,336 Views)
I think "resample waveform" is the way to go - but I think you shouldn't need anything else.
Just wire 1/600 to your dt input. This will reduce your output sampling rate to 600 Hz.
I'm really curious why you need to reduce the sampling rate. Care to share?
Regards
Florian
(3,328 Views)
