need help on treating strings
I need to remove all spaces in below string and put the data in string/dbl array. e.g. array[0] contains "04:00", array[1] contains "0.4" ... . so and so forth... array[8] contains "0.00D"
I have tested with match pattern and it doesn't work. 😞
"04:00               0.4       3      17      13       4    0.00D   0.00D   0.00D"
can anyone help?
thanks
(2,509 Views)
Hi m_min,
try the attached example.
Hope this helps.
Mike
(2,501 Views)
