need help building .exe when using 3D correlation surface
When trying to build an executable with the 3D correlation surface VI, I receive an error . . .
Error 6 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_Item_OnDoProperties.vi -> AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Generic file I/O error.
9/10/2009 9:25:09 AM
I receive the same error when creating a new project and inserting the NI example program (3D Contour Plot.vi) into the project (it is the only file in the project).
thank you.
(3,241 Views)
Hi PikesPeakLV,
Are you able to build an executable out of other projects? Just try with a new project and a blank VI as startup and see if you can execute it.
(3,234 Views)
Yes, I am able to create a simple .exe
(3,227 Views)
Hi PikesPeakLV,
I was able to build an application using the example that you mentioned in LV 2009 on Windows XP SP3. I would like to know more details to figure out whats incorrect.
  • What are the NI Softwares installed in your system and what licenses you have?
  • Which Operating System you're using?
  • What is the location where you're attempting to store the build in? (Are you changing the default location?)
  • Is there any settings that you are using apart from the default settings?
(3,218 Views)
