need a simple VI to convert voltage into sound
I have NI DAQPad 6052 and I need a VI that converts the voltage I read from channel0 into a sound that is proportional to the voltage amplidute.
(3,904 Views)
amiliotis;
You can generate a sine wave and generate a sound. Vary the frequency of the sine wave depending on the voltage. There are two examples included with LabVIEW that shows you how to generate sounds with the sine VI (Simulate a Telephone and Generate Morse Code)
I am attaching an example. I create it in a couple of minutes, so make sure you test it and understand what is going on. It should give you a start.
Regards;
Enrique
www.visecurity.com
www.vartortech.com
(3,904 Views)
For conversion of voltage to proportional sound, you can employ Vi put in LV function pallete-> Graphics & Sound -> sound -> SO Volume.vi.
In this vi, there are 2 input (Left & Right),feed your scaled voltage to both Left & Right inputs.
Before using SO volume.vi, offcourse you need to put other vi for initialization & configuration of sound output. These Vi can be taken from Sound-> Sound Output pallete.
Hope this helps. Your feedbacks are welcome.
Best Regards,
Nirmal
(3,904 Views)
cool
When you feel sad, laugh
(3,904 Views)
