need Kikusui Load PLZ664W series drivers..please help!
The exe should have all of the necessary functions in the driver and you should not need to install anything else. Something is causing a syntax error. Has the exe ever worked? Have you turned on NI-Spy/NI-Trace to look at the commands being sent?
Message 11 of 12
(384 Views)
Hi Chintan,
Your issue seems to be related to communication problems with the device. I would recommend you to post this in a new discussion forum, because this one is already closed and is related with another issue. You can add more information about this issue: was this working before? Is the .exe for this device? Is it working in the develop computer?
steve.bm
AE | NI
Message 12 of 12
(364 Views)
