ncConfigCANNet.vi returning 10003 error code
When running ncConfigCANNet.vi I get a 10003 error code. Both ports on the CAN card Pass the test ports utility diagnostics.
(2,711 Views)
Hi there,
If you have a look in tools>>explain error. This tells you that the error code refers to "The value of a numeric parameter is invalid."
What numeric properties are you passing to the VI?
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(2,702 Views)
