navigation betweet two interfaces
HI everyone
plz how can I navigate betweet two intefaces labview (e.g if I selecte a button from one interface it will takes me to the other one)
cordially
Message 1 of 9
(4,545 Views)
@asso24 wrote:
HI everyone
cordially
interfaces?
What do you mean?
Message 2 of 9
(4,524 Views)
hi
(interface labview) = front panel
Message 3 of 9
(4,516 Views)
It is still not clear exactly what you want to do.  Two possibilities come to mind.
- Use subpanels.
- Or set the VI Properties >> Window Appearance to "Show front panel when called." You may also want to check "Close afterwards if origianlly closed."
Lynn
Message 4 of 9
(4,501 Views)
@asso24 wrote:
hi
Honestly, why haven't you taken the free LabVIEW tutorials yet?
Message 5 of 9
(4,500 Views)
Yes, first go though the FREE tutorials the when you know enough about LabVIEW to begin tackling your basic problem, check out this post and the couple following it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 9
(4,451 Views)
hi everyone I think that you misunderstand me
If I insert the name and the password and I click to the "ok" button It will takes me to another VI , how I can do that , plz have anyone  an idea about te diagram
plz see the pic bellow
sorry about my english it is not my language mother
cordially
Message 7 of 9
(4,441 Views)
OK, well the complete answer depends on how the rest of your code is structured.
1. You can as Lynn suggested do something with subpanels,.
2. You could dynamically launch the other Vi when correct information is entered.
3. The other VI could already be open but hidden and blocked by the modal sign on screen.
There are a lot of options.
Mike...
LabVIEW Champion
Message 8 of 9
(4,431 Views)
The simplest method is to have a top level VI that does not show its front panel.  This top level VI is often a state machine.  So in your state machine, you just state which VI you call.  If you need to show the front panel of that VI that is being called, use the Show Front Panel When Called and the Close Afterward option in the VI properties.  So when you call that VI, its front panel will show.
Message 9 of 9
(4,384 Views)
